help
Solved by Gazereths,
What game are you trying to run? You said you are running the intel inegrated graphics HD3000, that is an extremely weak graphics solution (it's the graphics chip onboard the CPU) and is not capable of running many games.
If you have a dedicated graphics card make sure your display is plugged into the dedicated graphics card not the motherboard's disaply output.
