The implication is It wasn’t the new drivers causing the slowdown, but something else.  That could be lots of things.  WiFi is radio and is subject to all kinds of interference.
https://linustechtips.com/topic/1279677-help-needed/#findComment-14291173
56 minutes ago, Nguyenable said:
  I was usually averaging speeds of 80 to 90mbs before. It started slowing down after i updated the Wi-Fi drivers, so I rolled back to the previous one. But now speeds have been constantly low
  Any suggestions would be much appreciated
This is unsurprising for WiFi. Not much else you can do really. It's sort of like how you can have really crappy LTE at home one day and blistering fast the next. Just as Bombastinator has alluded to, since it's a broadcast medium, it's never going to be reliable 24/7 as a wired connection. It's very possible it was always like that prior to your driver update, you just never noticed. No one checks that WiFi status window every day.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1279677-help-needed/#findComment-14291179
That 72Mbps is currently negotiated maximum speed between your computer and wifi access point. So speed in WLAN, local wireless network.
Speedtest on the other hand show speed of your internet connection.
These thing are related only in this way: Internet speed < WLAN speed. So this looks perfectly fine.
If you want higher WLAN speeds, try to force using 802.11n or newer (if your wifi ap and computer support it).
https://linustechtips.com/topic/1279677-help-needed/#findComment-14291962
