Do I have enough power???
Go to solution Solved by Simply Tom,
So I tried a different power supply and no boot. I guess I have to RMA it. Thanks for all of you help.
Headroom to spare too.
https://linustechtips.com/topic/127830-do-i-have-enough-power/#findComment-1699635
The pc powered down when playing a game and now won't boot so I am not sure if it is the PSU or the card.
Something isn't plugged in all the way, software fault, shorted the mobo by accident, or the psu died? Does the system turn on without the gpu in it?
https://linustechtips.com/topic/127830-do-i-have-enough-power/#findComment-1699668
try this and run off iGpu
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/127830-do-i-have-enough-power/#findComment-1699687
maybe the psu rails cant cope or the psu has just literatly BROKE :mellow:
The PSU is more than enough to handle all those components. Something us faulty
I am trying it another computer with a higher wattage PSU to see if it is my PSU.
https://linustechtips.com/topic/127830-do-i-have-enough-power/#findComment-1699785
The problem is not in the PSU, because with this one you have more than 150W to spare. Are teh fans on your graphics card spinning upon boot up?
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/127830-do-i-have-enough-power/#findComment-1699833
