Questions about Corsair RM750x PSU and CableMod Pro ModMesh cable connections
Solved by Juular,
I suppose they just went the easy way and made the second half of EPS possible to plug into the 4-pin, there should be two cables IIRC and one of them isn't like that but i'm too lazy to look it up rn (i have RM750x myself). In any case pinout of all additional CPU power connectors is very easy, top row is +12V, bottom row is ground, so there are no way you fuck this up unless you shove it rotated 180° which shouldn't be possible because motherboard side is keyed no matter what.
