Help me decide between Gigabyte Vision D B550 and Asus TUF x570-Plus
Solved by Haro,
1 minute ago, 5h0ckw4v3 said:since I'll be working from both locations.
Then yeah as I said, the B550 aorus pro (or the V2), The B550 tomahawk/ gaming edge wifi, the B550 Strix f, and the X570 tomahawk are pretty good.
If you want to go with a white board, the B550 strix A is a good board, it's a Strix f but in white, if you want to go with a Vision D, you can, there's nothing really wrong with that board, just a little overpriced for what it offers, though it's still solid.
If you're set on a 300 dollar board, the X570 unify is good.
But yeah as said above, even if you go with B550, you'll still get Gen 4.
