Is it a good idea to power two GPUs with one 6+2 cable?
SparkFox621
I have a GTX 1060 and I'm buying an RTX 3070. I need to upgrade my PSU, and I'm looking for my cheapest option.
I need 4 6+2 connectors in total. One for the CPU, one for the 1060 and two for the 3070. My PSU has PCIe cables that have one input end and two output ends (like this one). So one 8 pin port on a modular PSU can be hooked up to two 6+2 devices.
The PSU that I'm currently looking at (Corsair RM750X) only has three ports for PCIe and CPU, but I want to hook up the 1060 + the 3070 with one cable coming from the PSU, another cable for the 3070's second power port and a third cable to the CPU.
Kind of like this: (hopefully the drawing doesn't fall apart after I post it)
│             │─────> CPU 4+4
│  PSU    │─────> RTX 3070
│             │                     Î
│             │────────┴────> GTX 1060
Is this a good idea or should I look for a PSU with four 8-pin connectors?
│             │─────> CPU 4+4
│             │                     Î
I recommend get a new psi with the 8 pin connectors
The CPU connector is not interchangeable with the PCI power connectors.
Why not connect the single 6+2 pin to the GTX 1060 and the double 6+2 pin to the RTX 3070?
Why are you keeping the 1060 in your system in the first place?
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Well there won’t be any load on the 1060 if you just game right? Assuming the psu can handle that card and cpu it should be fine.
Id still get something with some headroom myself.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
The RTX 3070 has a power rating of 220W, and I've read somewhere that in most cases the 8-pin cables can only carry 150W. Plus I'm sure there is a reason why the engineers put two separate 6+2's on the RTX card.
After I get the card, I will finally be able to switch to linux. I also have VR, so I will need a Windows 10 VM, and this way I can pass one GPU to the VM while keeping the other one on the host.
the 3070 spikes way past that. And it's 150w from one 8 pin, 150w from the other, and 75w from the pcie slot. So with dual 8 pins, you could pull 375w.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
