Will a 700 Watt PSU be enough for an RTX 3060 Ti?
MrVot
I'm going to be building myself a PC soon and am interested in the Gainward GeForce RTX 3060 Ti 8GB Phoenix "GS" but I'm not sure if the 700 Watt 80+ Silver PSU I've ordered will be enough.
What 700W 80+ Silver PSU is it, and what other components will you be powering?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I'm thinking of a Ryzen 5 3600X and the PSU is from a lesser known brand but the reviews were very good. It's an nJoy Legion 700.
The wattage is good, but make sure the PSU itself is good. You would probably want a good 600W unit rather than a mediocre 700W unit.
geometry is hard
b550 > x570
Just now, MrVot said:
I'm thinking of a Ryzen 5 3600X and the PSU is from a lesser known brand but reviews were very good. It's an  nJoy Legion 700.
Just because the reviews are good doesn't mean it's a good unit.
For instance the diablotek 350w PSU has 4/5 stars, but it's known to be one of the worst PSUS of all time.
geometry is hard
b550 > x570
Just the fact that it doesn't support full-range input alone makes me very skeptical of its quality.
I'd get something better for an Ampere GPU.
Good "reviews" or good actual reviews? Newegg and amazon "reviews" aren't really reviews, since they basically boil down to "I like it, 5 stars" or "I didn't like it, 1 star" without getting into the meat of it.
As for wattage, the 3060 ti and Ryzen 5 3600 would consume close to 350 watts or less under a stress test. 700 watts is overkill my a mile.
Primary PC:
I would look at a 650W PSU from a reputable company such as EVGA, Silverstone, Seasonic
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
What exactly is your budget for a PSU?
geometry is hard
b550 > x570
The problem with some system builders is, they pick up nice parts for their build, but cheap out on the PSU, which is an irony as the PSU is the most important part of a system build. Go for a good quality 650W PSU (at the very least, doesn't hurt if higher) from Corsair, Seasonic, SilverStone, Enermax, etc.
Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
as everyone above said get good quality psu, rm650x prefferably
I have been using a 600 watt corsair unit for a 3070 with 3800xt, zero problems. You should be fine. Go with quality over quantity, as others have said.
