Why does a I5 10600K run cooler than a R5 3600.
3 minutes ago, redcan0 said:He uses a Silverstone PermaFrost 240mm AIO
I use the same AIO but 360mm version.
He didn't change anything in Bios in terms of voltaje and clocks. But I don't know how he gets that kind of temps.
I also checked the power consumption while his CPU was idle and it was around 19 Watts.
My CPU takes 40 Watts while idle.
Could this be the reason?
Why does my take up so much power in idle?
idle temps and power consumption don't really matter. you should only compare load temps and power.
power consumption can only be measured accurately with a power meter inserted in the socket.
getting 25c at idle is not possible, unless the ambient temps in your friend's room are less than 15C.
make sure you both use the same software for monitoring temps (hwinfo64 is the most reliable)
