I've been having issues with my system not wanting to boot when I enable D.O.C.P. settings in BIOS. I have made various voltage, frequency, and timing adjustments, including the ones included in the "for Dummies" thread. The RAM refuses to run any higher than 2133MHz.. I've read that Ryzen doesn't like 4 DIMM setups, maybe that is the issue? Maybe the system doesn't like the RAM? I'm certain it probably isn't top of the line, but it was there for a good price. Maybe I'm just doing something wrong? There's no sense in the extra memory, if I can't get it running at least CLOSER to its rated speeds. In the end, will it really matter? I was always under the impression that Ryzen loved high speed memory, so I figured I could benefit from the extra speed.
This is the setup I'm currently testing this on:
ASUS PRIME B450-Plus
Ryzen 2700x
Corsair Vengeance LPX 32GB (4x8gb) 3200MHz (CMK16GX4M2B3200C16)
https://linustechtips.com/topic/1275393-docp-fails-to-post/
4 dimms is much harder to run stable on cheaper motherboards. A more expensive motherboard would have thick traces or even a different memory trace layout which would allow for better signal integrity so you could run your memory fast more easily. Basically all X570 motherboards, for example, would be at least decent at 4 dimms setups.
Yes, ryzen benefits quite a lot from increased memory speed. The core to core communication is based partially on the memory, so lower latency and higher bandwidth is best.
Is DOCP offering different speeds? If 3200 isn't working, how does 3000 or 2933 fair? What if you manually increase the memory voltage a bit?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259241
Your board is likely okay for 3200mhz (I didnt look up specs) in 4 dimm slots, but that CPU memory controller is only rated at 2933mhz.
Id set DOCP profile, then manually set frequency to 2933mhz - I bet it posts.  Just with loose timings.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259246
1 minute ago, Moonzy said:
4 stick at 3200 is a bit of a tall order for zen+
try enabling DOCP but set freq to 2933? or maybe lower
To expand on this point @DrLanG I can push 3600mhz across 2 dimms on my R7 1700 with manual overclocking.  But as soon as I go to 4 dimms, stock settings only (2666mhz, due to CPU memory controller and likely the board as well, I think the board only guarantees 2933mhz across 4 dimms iirc)
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259255
So I've heard.. I guess I should've put a little more thought into things like that when the system was first built, but I was really just going for decent bang for the buck at the time. That's what was there.
DOCP offers me the 3200MHz profile, but allows me to adjust the frequency.. Therefore, no timing or voltage changes.. I've tried both 3000 and 2933 using the timings and voltage provided with the 3200 profile, but no luck. I tried increasing by .05v, from 1.35v to 1.4v. Also no luck there.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259285
I read something about that and gave it a shot. I tried 2933 with the voltages and timings that are included in the 3200 DOCP profile, nothing.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259309
52 minutes ago, DrLanG said:
I'm curious if maybe 4 sticks just wasn't the move. Seems to be too finnicky with my current setup.
Eh, Id personally disagree - Ive messed around a metric F ton with Ryzen first gen, rated at much lower, with (check my sig 3600 and 3200mhz stable) success on 2 CPU's way over spec (both 1700's).  Just need to find that sweet spot, as the solution above technically should work, or Id look for a refund on parts as you are not able to hit spec.
Pull CMOS, let it clear for a minute, put it back in and try DOCP settings, manually turned back down to 2933mhz frequency (leave all other settings alone) If this doesnt work put it on Manual and set the frequency to 2933mhz, and voltage for ram at 1.35v (DOCP setting, but this time we arent asking for specific timings, we will let the system pick) - one of these will work, or something with your setup is wrong (imho) - tightening up timings afterwards is a diff story.
The best way to check your hypothesis (and you could be right, but that means the board or CPU isnt working right to spec) is to remove 2 sticks (remove the stick closest to CPU, and the third one from that.  You should have sticks in the second and fourth from CPU in the mobo) and work on that.
Let me know if any traction gained if you are willing to try these things out
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259463
I'll try it out.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14259526
2 hours ago, DrLanG said:
I'll try it out.
If that doesnt do it, we will want to look at your stock SOC voltages and VERY LIGHTLY increment those up.  I believe up to 1.2v is MAX you want it, but I cant remember havent researched this in a while.  Basically iirc you may have to hit up to 1.15v on the SOC to get it stable.  Its been over a year since I learned all of this and havent messed with it on a physical hardware level since.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14260030
  • 3 weeks later...
Okay. I've been busy, but I've finally gotten around to trying the suggested solutions. Without using any of the DOCP settings, I was able to achieve 2866 at 1.35v and SOC at 1.1v. Hitting 2933 is a different story. I tried increasing the SOC up to 1.2v, nothing. Maybe a RAM voltage increase? I mean, 1.35v was the voltage in the 3200 profile, so I'm not sure if that would change anything.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311746
You crazy? These can barely handle 2 sticks at DOCP, lower MHz and try again...
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311759
Careful with SOC voltages, research maxes there I dont go over 1.15-1.17 iirc when overclocking ram.  You can also go up to 1.4, 1.45 on the voltage for the RAM.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311763
Huh?  No he should continue to dial them in and see what he can get.  Its free performance.  His system is unstable because the CPU wont DOCP because the CPU memory controller is only rated for 2933mhz.  Board is safe, memory is safe.  Not sure why this response.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311765
With four sticks he is lucky if he barely get 2933MHz or maybe 3066MHz...
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311767
If he gets 2933mhz thats free performance.  Yes getting 4 sticks is more difficult then getting 2 sticks dialed in on Zen/Zen+.  I know this from Zen release that its near impossible on that series of processors (I cant get past 2666mhz on 4 dimms no matter the mobo, CPU, or ram kits I have and try)
Sure he can stop, sure he can try to dial down, but as long as he is within the safe operating limits, has the time and desire - there is no reason not to try to get this stable.  Worse case...he learns a bit about overclocking.  Best case - he dials it in for free performance.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311780
Maybe increase timings to get more MHz is a option, tough on Zen+ that wont gain performance since there is no infinity fabric...
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311782
Wut?
Edit - you should google what you just said.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311788
1 minute ago, Tristerin said:
Wut?
No I am quite sure sunce there is no CCX in Zen+, 1st and 2nd gen also likes low cas latency... The best OP can do is to try and see if he gain anything from trading CAS for MHz but I doubt it...
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311796
First thing that comes up on google:
The Infinity Fabric: A Blessing And A Curse - AMD Ryzen 5 1600X CPU Review | Tom's Hardware
AMD Ryzen 7 1700 Review - A Little More Architectural Detail (guru3d.com)
I personally have alot of time, and kits of tested DDR4 invested into Zen platform, and the only thing that doesnt care about frequency and CL is CinebenchR20 :)  The things that do care are games, and they prefer frequency over CL if you were to pick a trade off.  Though I have no experience with Zen+ products the same results likely occur in gaming which is a slightly higher average frame rate, but exceptionally tighter frames and a huge boost to lows.
https://linustechtips.com/topic/1275393-docp-fails-to-post/#findComment-14311878
