Pop Os 20.04 not booting after system upgrade
I have fixed the Issue using this suggestion ./amdgpu-install --no-dkms
https://askubuntu.com/questions/1287904/amd-gpu-dkms-not-building-in-kernel-5-8-5-8-
Can I assume that my assumptions b4 about the new amd driver having a script within it that configures the new 5.8 kernel in a different way than the dkms program is told to do it - Is the actual reason this is happening, If I try to install the amdgpu drivers without the --no-dkms flag, I always get errors regarding dkms. This is the 1st time I have not got any errors?
Im still not fully aware how dkms works so the question is am I fine to use the amdgpu driver like this or can anyone foresee any further issues?
I might be kicking myself in the nuts with my next move, but I plan to allow the Pop-update to run to see if it will stick with this setup ( as Id like upto date apps etc ) I cant see anything regarding the amd drivers on this run ... so
At least for the moment, I have a way around the current issue as long as you peeps cant foresee any issues with me not installing it using dkms.
Il update my progress if it stays stable
Massive thx to all that inputted .. Especially you Nayr438 ... ure answers opened the door to this result ... Kudos
