Pop Os 20.04 not booting after system upgrade
I have fixed the Issue using this suggestion聽聽聽 聽 ./amdgpu-install --no-dkms
聽
https://askubuntu.com/questions/1287904/amd-gpu-dkms-not-building-in-kernel-5-8-5-8-
聽
Can I assume that my assumptions b4 about the new amd driver having a script within it that configures the new 5.8 kernel in a different way than the dkms program is told to do it - Is the actual reason this is happening, If I try to install the amdgpu drivers without the --no-dkms flag, I always get errors regarding dkms.聽 This is the 1st time I have not got any errors?
聽
Im still not fully aware how dkms works so the question is am I fine to use the amdgpu driver like this or can anyone foresee any further issues?
聽
I might be kicking myself in the nuts with my next move, but I plan to allow the Pop-update to run to see if it will stick with this setup ( as Id like upto date apps etc ) I cant see anything regarding the amd drivers on this run ...聽 so
聽
聽
At least for the moment, I have a way around the current issue as long as you peeps cant foresee any issues with me not installing it using dkms.
聽
Il update my progress if it stays stable
聽
Massive thx to all that inputted .. Especially you Nayr438 ... ure answers opened the door to this result ... Kudos
聽
聽
