UPS APC intolerable noisy. Ups Apc Srv3ki Smart 3000v very noisy. Why they do not use 120mm fans! LINUS make a review UPS for a 1000W PC!
8 minutes ago, Alan Mattano said:Ok 1000VA = 525 watts + margin
Not sure I follow the math... generally VA = W, give or take 10%.
8 minutes ago, Alan Mattano said:also if I'm rendering or backing in SLI and TV 50 4K + some extra 100w marin connected like accessories headphone audio.
Don't connect monitors or accessories to the UPS. It's job is to make sure the computer continues to run, not so that you can continue to use it seamlessly.
8 minutes ago, Alan Mattano said:And I know I will go two 3090 for modelling and painting textures
Are you really sure you need dual 3090s? If so, you're going to have to live with UPS in the enterprise spec (read: loud).
8 minutes ago, Alan Mattano said:The problem is that if I go low I need to replace the battery more often.
No. You only need to replace it when it wears out, and if what you say is true (seconds per day), you'll be fine for a while.
