fps drop please help me
Go to solution Solved by SavageNeo,
Anistropic filtering on? That setting literally eats away your fps.
can anyone help me ive been getting lower fps in gta 5 40-50 fps in the city and 60-80 when flying does anyone know why this could be happening ive already checked the drivers taskmanager and changed the games settings but nothings works
https://pcpartpicker.com/list/fKvRF8
https://linustechtips.com/topic/1274383-fps-drop-please-help-me/
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
It’s a good chance GTA5 is unloading things while you fly.  It has to load more when you’re on the ground. More stuff interacts ECT.   So it’s not a problem as much with your pc, it’s a problem with GTA.   You can lock frame rate at 60 if it’s too disorienting, but im afraid you’ll have to live with the low FPS for aslong as you have your computer un-upgraded.
Also are you using a HDD or an SSD
im using a hdd
18 hours ago, iamlegs said:
yes i have it on max what does it graphical change and should i turn it off or just lower it
take it off or lower it,
