What cooler and thermal paste to swap to.
skullrebell
Hi there I'm working on swapping my case and my cooler won't fit, I don't have the stock cooler anymore what will be a good change to fit this case my budget is 200$ usd for case paste and cooler https://pcpartpicker.com/list/8TNH3Z
Its a Championship not a Belt!
56 minutes ago, skullrebell said:
paste
https://www.amazon.com/Noctua-NT-H1-Pro-Grade-Thermal-Compound/dp/B002CQU14A
case
https://pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg
57 minutes ago, skullrebell said:
cooler
keep the one you have
this is a lesson learned. Research the case compatibility first.
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
1 hour ago, skullrebell said:
The cooler price is somewhat wrong?
    $249.00
Edit ah it is. £64.99
For that price I'd recommend Scythe Fuma 2
https://www.amazon.com/Original-Design-Towers-Cooler-SCFM-2000/dp/B07QMK5R45/ref=sr_1_2?dchild=1&keywords=fuma+2&qid=1606319622&sr=8-2
I edit my posts more often than not
The SE-224-XT is a slight downgrade but you could reuse the NF-F12 on it if you're not planning to resell the cooler. https://pcpartpicker.com/product/VTqBD3/id-cooling-se-224-xt-basic-7616-cfm-cpu-cooler-se-224-xt-basic
Alternatively, the Mugen 5 Rev. B would be a bit of an upgrade: https://pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-5117-cfm-cpu-cooler-scmg-5100
