Hey, so im planning on buying a cooler for my 4770k, which i will overclock.
im having a hard time deciding on one. im on a really tight budget and i wanted to know what coller will do. i also wanted to know if the 212 evo is good enough for it
 if not, can you recommend me on anything from this list:
 yTDlF4V.pnghttp://i.imgur.com/yTDlF4V.png
 thanks.
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/
From that list, I would go with the Cooler Master Hyper 212 EVO.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1692944
Evo
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1692949
Do you plan on doing any overclocking? If so, get something like a Noctua NHD-14
If not, get the 212 EVO like everybody else has said
He's on a tight budget, the D14 would most likely be out of his price range.
Evo is a really good cooler for the price.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1692974
212 Evo.
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1692978
Hyper 212 if you are on a budget.
NH-D14 if you want to get some higher overclocks since Haswell runs really hot.
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1692983
212 EVO can do its job very well, as I've seen, it's a good choice.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1693338
Yeh, 212 EVO if you are  on a budget, or have a neat little(ish) system. Other than that i will definitely reccomend the Noctua NH-D14, because it is silent and have awesome temps(i have a 4770k at 4,5ghz under mine with no problems :)).
i do plan on overclocking, the reason i gave you this list is because these are the cpu collers in my budget from the store im buying the pc from.
 i can buy the nh-d14 from another store the problem is that i dont really know how to mount it.
 should i still get the d14? and does it worth the extra money.
 EDIT: and will it fit on a fractal design r4 with a maximus vi gene?
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1695742
It fits my XL R2 fine so it should with the R4. If you're worried about mounting it just look up some videos on youtube. I personally have the D14 and it was totally worth it as it only goes up to 70C under IBT (MAX) at 4.4GHZ.
i7 4770K @ 4.5GHZ, NH-D14, Kingston HyperX Black 8GB, Asus Z87-A, Fractal Design XL R2, MSI TF IV R9 280x, BTFNX 550G
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1695799
YES it fits in an R4.
The build in my signature is my gaming PC and the NH-D14 fits perfectly  :)
MY CURRENT PC
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1695809
The evo can do 5GHz easily and theres no performance difference between the nh-d14 & evo on haswell.. You're hitting a thermal wall before you even push a 212's to its limit.
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1701302
the evo 212 will handle 4.5-4.7 Ghz with no problem?
Of course. The problem with ivy bridge & haswell is between the die & metal cover (look http://media.bestofmicro.com/ivy-bridge,6-L-335901-13.jpg), usually the die was soldered to the heatspreader (grey metal cover) but since Ivy bridge they started to use thermal paste and glue the heatspreader that's causing a heat dispace bottleneck meaning that there's not enough heat being transfered to the heatspreader. So basically you would hit a thermal wall, there would be only around 50% of a 212 cooling capacity utilized and if you get a better cooler like a nh-d14 you're utiziling 20-30% of it with the same exact temperatures. Customloop is a waste for them.
Since heat & wattage are synonymous; a 3930K's power consumption is a lot higher than a 4670k/4770k, an evo can easily handle a 3930K@4.2-4.5GHz & or another example the evo was perfectly enough for a 2500K@5GHz which would mean a 4670K is not even a challenge for a 212.
You won't pull more clocks with a nh-d14, that's complety false. That would only happen on S2011 cpu's or AMD cpu's or Sandy bridge, not on haswell/ivy bridge.
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1707520
My vote goes for the NH-D14 since it's one of the best coolers out there. I have one in my other builds and it's able to handle my 3570K at 4.7Ghz like a champ. Here's a review showing the NH-D14 handling a 3770K at 4.6Ghz. Your 4770K will of course run hotter but it should give you an idea of how good this cooler is.
https://linustechtips.com/topic/127273-cpu-cooler-for-4770k/#findComment-1707573
