Converting FLV to MP4 without re-encoding on handbrake?
Solved by Kisai,
On 11/23/2020 at 6:46 AM, williamcll said:on ffmpeg, all you need is to enter ffmpeg -i input.flv -c copy output.mp4 and it would just remove the flash parts of the video. How do you do this in Handbrake?
Handbrake is just a wrapper over ffmpeg. FLV is not flash, it's just a video container that the flash player knows how to read.
Pretty much ALL the "gui" tools out there, even ones you pay for use ffmpeg as their backend, so they all have the same feature capability. AVIdemux is actually a video editor, but it's designed to cut videos, but can re-encode them.
You can't get any easier than using ffmpeg itself to this simple thing though. Just create a batch file/shell script if you don't want to look at the terminal
rem container change with ffmpeg ffmpeg -i %1 -c:av copy %1.mp4
