Using a router as a switch?
Solved by thunder9231,
You're making this more difficult than it has to be...
- Unplug secondary router from the main, factory reset if needed if you can't remember any changes that you have made
- Following the MAIN router's IP Addressing scheme, change the 192.168.1.1 to x.x.x.2 or x.x.2.2 (Replace the X with the numbers from the main router) then SAVE
- Type in the new IP address that you just changed, then DISABLE DHCP Server. SAVE
- Go into advanced routing, change the Operating mode from Gateway to Router. SAVE
You now have a switch with a built-in access point
Any IP addresses are determined by DHCP on the MAIN router. NOT the secondary
Don't plug incoming network from main router into the WAN port on the secondary. It will not work. Plug into the LAN ports
