Case Fan Questions!
Solved by minibois,
1 minute ago, js5836 said:They have a 3 pin 12 V connector. Could you quickly explain PWM to me, or just drop a link or something. I would really appreciate it!
The most important thing to know about PWM (4 pin) vs DC (3 pin) fan control, in the context of PC fans can be explained using these graphs:
DC fan control is more basic, it doesn't allow for nice fan curve, but rather fan steps. It also can't run a fan as slow as PWM can.
PWM in comparison can run fans slower and allows for a better fan curve to be set.
PWM is not nescecary, it is just extra luxury, compared to DC fans.
