Have Linus tried to Overclock a Monitor?
Isaac Foster
So, there is an app called, CRU (Custom Resolution Utility) that makes your Monitor Hertz or Resolution bigger. I tried it and it actually worked! I tried to push my Laptop Display from 60 to 61 Hertz and it works, i tried on my Living Room TV, and you know what? Its a 75 Hertz TV now, but the Resolution overclocking doesn't work for me tough, what about overclocking a 360 Hertz monitor to 400 Hertz Monitor! Its the same Hertz as our eyes! I have a feeling that it doesn't work tough. But i guess, worth of shot, Linus?
So then lets get started!
So first download CRU : \https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
All the tutorials are on there
WARNING! This might make your GPU Unstable! So, take your own risk!
And if you have errors like Resolution not supported use another HDMI ports on Monitor, on Laptops, use a TV, then delete the OC Options that you just make, and it will work again.
Oki then Good Luck!
And btw its not a virus so don't worry :D
That message make me a little bit sus but i don't really care.
He has. In the video where he overclocked everything.
tbh I personally don't see too much point in overclocking a monitor unless if its 60hz or lower.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
