5 minutes ago, Spooky45 said:
how to fix this "The Noctua NH-D15 82.5 CFM CPU Cooler may require a separately available mounting adapter to fit the MSI MAG B550 TOMAHAWK ATX AM4 Motherboard."
Either grab the SE-AM4 model: https://pcpartpicker.com/product/shNypg/noctua-nh-d15-se-am4-1402-cfm-cpu-cooler-nh-d15-se-am4
Or just assume the cooler you're buying has been received by the store after 2018 (which is very highly likey), so you can ignore the warning.
Quote
Socket compatibility: [...] AM4 (included since 2019, older coolers require NM-AM4)
https://noctua.at/en/nh-d15/specification
https://linustechtips.com/topic/1269069-help/#findComment-14211247
On 11/14/2020 at 5:08 PM, Spooky45 said:
does this mean i could just buy
Unless the store you are gonna use is small and in remote location, yes. Besides, you can check from store page/ad what sockets are supported.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1269069-help/#findComment-14214160
Yes. If you want to make sure, contact the store for confirmation that it comes with AM4 mounting hardware.
https://linustechtips.com/topic/1269069-help/#findComment-14220334
