Try hitting it with a hammer or put some isopropyl alcohol in-between the two, whichever is easier. A razer blade perhaps.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
11 minutes ago, PineyCreek said:
Twist at the corners, don't pull.  If it's that stuck, what did you use for TIM? Superglue?
its more common than you think, i ended up having to put my cpu cooler in a vice and use a chisel to get the cpu lifted one time.
bad idea to hit it with a hammer, its a PGA cpu, so the pins will easily get damaged either by the hammer, or when it flys off
OP, i reccomend using a cut out piece of a tin drink can, just be careful not to cut yourself, isopropyl alcohol helps too
youre lucky, it looks like none of your pins got damaged
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
3 minutes ago, Letgomyleghoe said:
-snip-
That was just me with a crappy jokes.
26 minutes ago, frost kazuma said:
Sooooo I cant remove my processor from the cpu cooler, tried to use a heat gun but it still wpnt budge :/
Twist, if that doesn't work try to slowly pry it up with a screw driver or go between it with an old gift card.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
4 hours ago, frost kazuma said:
Fuck i might broken the motherboard when I removed it with the cooler.. I added my new processor and it wont even boot to bios
I had lots of "pulling CPU out with the cooler" moment but none of them bricked/borked the mainboard.
10 hours ago, frost kazuma said:
Finally removed it using paint thinner and a very thin screw driver it took hours jesus
Did you accidentally put glue on it instead of thermal paste? A nudge/push from side should loosen the thermal paste grip.
Is it a new ryzen 5000? Maybe you need a bios update. Had the same problem with a B550
