PSU cooler
Go to solution Solved by boggy77,
not much you can do. return it and get a better one
hey guys my case fans are all silent but my power supply is an absolute jet engine, how can i make it quiter without putting my pc on carpet etc.. because it is really annoying that everything in my new rig is silent exept my psu (i have tested eg. i put my head in the case and listened to the fans to see if they were loud. they are silent so basically it can only be the psu) here is my pc - its my first ever build and i did it yesterday
https://linustechtips.com/topic/1268250-psu-cooler/
What power supply are you using?
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14204366
it is not the worst, but is pretty loud indeed. also it is not the best. you should replace it. check our tier list and get anything from tier B or above (blue/gold named are pretty silent at load)
https://linustechtips.com/topic/1116640-psucultists-psu-tier-list/
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14204405
Save up and get Seasonic 650W 80+ GOLD GX. It has a silent mode and even without it on its still not loud whatsoever. (A bit expensive at $120, but well worth it)
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14204406
ok ill save up and get a modular one later  the cables are kinda ugly on it anyway. chhers for the help. it literally makes my pc sound loud. the fans are all silent i have 1 nzxt one that came with the case 2x 140 mm corsair f series fans and the fan that came with the aio
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14204412
do NOT put your PC on carpet unless fire is what you want to start
do not choke the intake of your PSU
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14204424
A bit off topic, but
Although correct in current config. The psu could be mounted fan up in this case and be just fine. So you could place it on the carpet
https://linustechtips.com/topic/1268250-psu-cooler/#findComment-14206762
