Looking for a cooler please help :D
DustHaze
Go to solution Solved by Fasauceome,
1 minute ago, DustHaze said:
I just want something efficient and capable of handling games and a stress test without the pc shutting down.
thermal shutdown would be the result of some seriously catastrophic CPU cooling, if you are currently using that Freezer 7 and it's causing shutdowns you have a more fundamental problem
If you don't already own that cooler, I think it's a fine choice, I personally use a Hyper 212 black which is very quiet with my overclocked i7
https://fr.pcpartpicker.com/product/HyTPxr/cooler-master-hyper-212-black-edition-420-cfm-cpu-cooler-rr-212s-20pk-r1
Hi everyone,
I'd like have your help in finding the cheapest but a capable cooler for the Intel  I5-10600 non K, this is my build
I will  appreciate any suggestions.
1 minute ago, AndreiArgeanu said:
Your part list is private
oh I'll see just a sec
you can always copy the permalink to share a parts list, no need to worry about private/public
Primary PC:
there you go refresh to see it.
yeah I just didn't pay attention thx for reminding me
are you looking for a cool and quiet CPU cooler? And do you currently have the Arctic Freezer 7 listed?
Since you can't overclock, you wouldn't benefit from a very expensive cooler.
Primary PC:
They said the Arctic is good enough but I'm not sure.
Primary PC:
can I get away with having the i5 the K version with this cooler without overclocking it on this motherboard?
you can't overclock on an H410 motherboard, a Z490 motherboard is required.
Do you already have these components? If not, you should make some big part swaps
Primary PC:
so the boost from the the K version is not functional on this motherboard, I mean no manual overclocking just the boost from the factory.
the boost from the factory is always enabled, it's just turbo boost. overclocking is when you go above the factory boost setting.
by the way, that motherboard has some pretty weak power delivery, it would likely have some trouble sustaining boost clocks in gaming, whether or not the cooler is good. On top of that, with memory locked to 2666, the gaming performance is going to be poor.
I highly recommend a build like this:
The CPU comes with a good cooler in the box, the motherboard has WiFi built in, and a less expensive PSU is still good here. You can afford some faster ram as well.
Primary PC:
Thx for the tips but I'd really like keeping the I5, I know the ram is locked by the cpu but it was the cheapest kit I could find, do you think the System Power 9  wont blow on me?
The system power 9 is a capable budget PSU, and 500 watts is plenty.
Primary PC:
I forgot to ask you, if I bought the "Gigabyte B460M GAMING HD Micro ATX LGA1200 Motherboard"  instead, does it have a good power delivery and how do you know it does?
My advice for a motherboard that's powering a 6 core CPU or greater is that it has a VRM heat sink. That motherboard does not have a VRM heat sink.
Primary PC:
You are right thanks a lot man, I appreciate putting up with my questions, you are the best :D
