I had an interesting experience with my internet today. I typically get up to 200-300mbps download and an average of 15mbps upload with an average ping of 11-18ms.
Today, when I woke up, half the websites I typically visit wouldn't load. And after running the network troubleshooter when you go to network sharing center, it said my DNS server wasn't responding. I then used my iphone's internet to google how to deal with this, and it led me to cleaning my browsing history, checking the same websites with different browsers(and all browsers had the same issues), and also to reboot my modem by unplugging it for a minutue, then plugging it back in. Nothing worked at all until about 30 minutes ago when things were STILL not working, but unplugging my modem for the 5th time today and plugging it back in solved it.
I've never had this big of an internet malfuction. Any idea what else I should have done today? I feel like I just got lucky with the 5th attempt to reboot my modem.
https://linustechtips.com/topic/1266811-how-do-i-resolve-dns-server-problems/
The way things work is your ISP hosts your DNS servers. Your clients query these servers to translate the website Domain Names into IP addresses. If your ISP's DNS goes down or your connection to them are severed in some manor you're effectively cut off from the Internet (unless you know the IP's of the websites you want to go to).
Chances are they got the service re-established and rebooting the modem that 5th time was just necessary for the modem to re-connect.
As Chionele as suggested you don't have to use your ISP provided DNS. You can use the Public DNS provided by companies like Google & Cloud Flare. Downside of this is unless you live very close to one of their servers your Ping is likely to increase as your DNS query has to physically travel farther before it gets resolved.
That generally isn't an accurate statement, it means that it couldnt resolve DNS...so it could be that your connection was just down, that would have resulted in being unable to reach a DNS server.
Clearing the browser doesnt really do anything for DNS< but it does clear cookies and temporary files forcing the site to be fully reloaded (as does using a different browser)
Unplugging/replugging in the modem, depending on the connection, does a "reset" on the line. If you have dynamic IP, then it will often also lease a new IP address which may be in a different scope which can resolve some issues depending if they have a configuration issue.
This isnt really a Server subforum thread, in future if you cant get your Internet to work, give your ISP a call.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
