I am planning a build and finding a nice case is turning out to be a struggle. I have a tempered glass version of the enthoo evolv that im currently not using, and while i do like the look of the case, i dont like seeing the rear side and the mess of cables. Does anyone make a solid back panel that uses the same screw mounting? or how much do you think it would cost to get a panel made?
https://linustechtips.com/topic/1265559-solid-back-panel-for-enthoo-evolv-atx-tg/
Unfortunatley getting a Non TG solid rear panel isnt an option since it uses different mounting
Evolv-ATX-11.jpg.cdecd0a0a29321e1c362a5b3edc1d7bb.jpg100031493_Evolv-ATX-11(1).jpg.00374911a83787297282d4954e2fa87a.jpg
Since you have the TG panel, it should be easy enough to make a template and then have a rear panel cut out or 3D Printed for you. Where you would go to get that done I'm not sure, hopefully a local fabrication shop would have the materials you need (thinner than 1/16" Sheet metal perhaps?)
12 hours ago, Blue4130 said:
1/16" would be very floppy/bendy. I had a side panel made for my case and used 1/8" stainless steel. Even that bows out quite easily.
The face and top plate are 3mm aluminium. i think the hardest part will be getting the finish to match
1/8"? I'd like to see that because I'm highly doubtful; that's VERY thick stuff, quite heavy and not easy to bend. Most panels are under 1/16" (2mm)
You could just get some matte window film and put it on the inside or outside of the panel. Hides the cables, looks decent and if it's on the inside you can be all about that extreme tempered glass that you can no longer see through look :p.
So it's not true 1/8th inch because I am in metric land. It's 3mm. Weight was not a concern.
