Maybe Less padding
Go to solution Solved by colonel_mortis,
I've reduced the padding in the forum and topic lists for the next update, although not as much as you have done in your screenshots.
On 10/31/2020 at 3:14 PM, Nayr438 said:
That looks very cramped to me.
Maybe it's just me, but the padding seems a bit excessive on the forum, especially on the shadows / outline of popup boxes. I have never been a fan of shadows/outline on popup windows though.
In my opinion something with less padding like this looks better than the default. These just pulled as an example, the padding on a lot of things however seems excessive.
Default
Just thought id share my thoughts on the new theme. So far I am liking everything but the padding.
Using Firefox on Linux if it happens to look different on a different browser.
https://linustechtips.com/topic/1263766-maybe-less-padding/
I just noticed this, so many shades of gray... It really doesn't make anything easier to read, much the opposite...
And also if you go to thread overview, there suddenly is no distinction between threads, except a thin white line...
Used to be 2 different shades of "gray" which made distinguishing between threads much easier. 🤷🏼
783415594_Screenshot_20201031-172723_SamsungInternetBeta.thumb.jpg.2f08cf48bf829db3cf4db49196049cb3.jpg
Like why, yes I know where a new thread starts, but it's very difficult to distinguish anyway, especially if you just come from a thread where there is an over abundance of gray paddings, it's like you're on a different website altogether almost!
(and it's really hard to distinguish between threads visually)
-Scott Manley, 2021
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14168028
I don't personally mind the color scheme, for the most part it fits quite nice in my opinion. I have never really been a fan of alternating thread colors, so that change doesn't bother me personally.
I started working on a Stylus theme for my personal use, I just cant get over the unnecessary padding and some of the font sizes.
Left Modified - Right default
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14168118
Idk. The padding seems fine to me and adds clear separation in the content rather then letting everything just blur into a single page like the old design did.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14168307
Tbh if you asked me before I had said alternating thread colors are useless... But now they're gone I sorely miss them... It's so hard to find anything!  🤷🏼
-Scott Manley, 2021
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14168364
HTTP/2 203
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14170879
@colonel_mortis
I think the text size issues (on mobile) are mostly fixed, if you compare this to my screen shot above
851147719_Screenshot_20201104-151142_SamsungInternetBeta.thumb.jpg.9586e1d2081b04a66da34e03c258ce15.jpg
So that's good, but there's another issue now and that's the space between things (is that "padding?) there's really a lot of " empty space" between topics / headlines now I think should be reduced, simply to get a better overview, like for example between
"The Hub"
and
"Forums"
It's just too much for me, but also between the topics themselves, I think it's really hard to navigate through so much empty / unused space.
Further I don't really understand why "Linus Tech Tips" is smaller than the "Hub" it should be the other way around imo - this time not for readability but for esthetical reasons.
Thing on top should be bigger than thing following, no? That's at least what I remember learning in school back then. ;)
Just, uh, I don't know, some things I still notice, especially the spacing that could be still improved, and I don't know if these things are still being worked on, so some feedback couldn't hurt either way, I thought.
-Scott Manley, 2021
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14178872
"The Hub"
and
"Forums"
Thanks for pointing out, this will be fixed in the next update.
The LTT logo is part of the site header rather than the page-specific content, and you'll see the same thing on other sites too. You know you're on LTT, what's relevant to you on that page is that it's The Hub.
HTTP/2 203
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14183334
You're welcome, glad to hear it. 👍
I see, it's just something I noticed that's visually not ideal imo, but I thought of that too that it might look weird if it's actually bigger, like I said it's not an issue for readability or usability anyway.
-Scott Manley, 2021
https://linustechtips.com/topic/1263766-maybe-less-padding/#findComment-14183361
