Is this worth it? I have the Magnitude 2066 block and 10980XE I would like to shave off at least 3C from stuff.
If so, what should I use to lap the CPU and CPU block? Thanks!
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/
Direct die is going to better and more definitive since CPU lapping requires skill and is no guarantee depending on the waterblock bowing. EK in particular sells supposedly plates specifically for lapped CPUs.
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14154376
I went the route of getting a custom machinef flat IHS and the flat EK magnitude cold plate since I had some super wonky core to core deltas even after a de-lid.
I kept the original IHS intact for resale reasons. This is probably a lot harder w/ the 10980XE though due to it being soldered.
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14154420
Would you say I should lap it myself? Not too hard following a tutorial. I don't get huge core deltas currently btw, but I'd love to drop extra 3C or so. It would put my temps in very comfy range.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14155238
i lapped my 2700x and the EK full cover waterblock and i dropped about 20c, i suspect one side or the other was crazy uneven or something prior because i was idling at about 78c on water prior to lapping it so i would never expect results like that for a normal case. used the same tube of thermal paste on reassembly and had tried reseating it prior, so i dono.
Also lapping the CPU is fun and a great way to kill some time, i started at 800 and ended at 10,000 grit paper, most people stop at 5-8k grit but i had some lying around so i ran that on there too and damn was that thing shiny :)
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14155531
I might do that. Tape sand paper to my desk and apply water and gently sand it in figure of 8.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14157781
Don't do this unless your desk is made from glass. It won't be flat enough and you'll end up with a finish no better than what was there before.
Use something like a mirror or sheet of glass.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1262179-lapping-ihs-and-block/#findComment-14162061
