Hey guys,
So I recently trash picked a Asus ROG G20 and it fired right up. I threw a WD Black into it and now its my main rig. I am a youtuber and when I am editing youtube videos the fan revs all the way up to the maximum speed and the computers performance becomes worse. I suspect its overheating but I have no way of knowing this. Should I be worried? If yes, what steps should I take to cool it down?
https://linustechtips.com/topic/1261752-overheating-cpu/
cam you ckecy the cpu temps on hwinfo64?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150844
I would prefer not to install any software to check my cpu temps. I'm kind of a neat-freak and dislike unessesary software. Even if it isnt overheating (Which im pretty sure it is) it wouldnt hurt for it to run cooler.
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150845
Ok, so you want us to guess, and refuse to help?
Bios database
prior build:
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150851
If you don't want to install any software to monitor temperature you could take the panels off to see if the CPU is not throttling. Installing HWInfo64 would really make it easier to monitor things without getting a thermal monitoring devices.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150861
Well I mean I'm not looking for a precise answer I just want a general answer on how to cool it down. I thought you could help me with this as I have little experience with computers compared to someone on LTT.com
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150862
Well im thinking before I do anything I should de-dust it and repaste it. Neither of those things have probably been done for 5+ years of continous use
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150866
I can, if you tell me what the tamps are lol.
Bios database
prior build:
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150867
Well... it really is the easiest way lol.
Take it apart and remove dust and add new thermal grease?
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150869
Just now, ILIKEBEEZ said:
Ah fuck this I will look elsewhere for basic knowledge. Many other people are willing to help me.
Wow, litterally everyone else mentioned a monitoring software (which you could uninstall btw). I'm a-ok with not helping you if you wont give any useful info.
Bios database
prior build:
https://linustechtips.com/topic/1261752-overheating-cpu/#findComment-14150882
