audio inteface...
If it can work as a soundcard and have a dedicated volume control, i think so.
https://linustechtips.com/topic/1261475-audio-inteface/#findComment-14148622
1 hour ago, Yarmoa said:
my question is, does a usb audio interface (like the U-Phoria UM2 USB audio interface) works as a headphone amp?
Yeah it does. Wont likely sound as good as a "real" headphone amp/DAC
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1261475-audio-inteface/#findComment-14148656
The UM2 would not be a quality headphone amp, the cheapest good option behringer makes for this is the MA400. If you really want the USB and/or XLR functionality the cheapest decent option is the UMC202HD.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1261475-audio-inteface/#findComment-14149779
