Give away
Go to solution Solved by WkdPaul,
* thread locked *
Nope, as per the Community Standards ;
Quote
No begging for free or discounted things, asking for donations, GoFundMes, or any similar content.
2 minutes ago, Pavan.k said:
 I am from India and thinking of starting a youtube channel. So can you give away msi pc
Linus does not read every single post here on the forums. Also, no, Linus doesn't just give away PCs.
https://linustechtips.com/topic/1260565-give-away/#findComment-14141210
* thread locked *
Quote
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1260565-give-away/#findComment-14141223
Guest
