Help me find a specific cable
Solved by wetblowdryer,
Ok, I have FINALLY found the solution. You obviously need a a good HDMI cable, which I have two now
. You go to general settings, external device manager, click on Input Signal Plus, select the HDMI input you want, ensure it is on full dynamic range in Nvidia control panel, and enable HDR in Windows. These options are NOT SELECTED BY DEFAULT and its label is not self-explanatory.
