Hi, I'm looking for a new laptop since my old HP Pavilion G6 is too slow now. I need the laptop for mainly University, office work and watching netflix/yt I have a budget of around £1000 but can go upto £1200 if needed.
Please if you have any suggestions could it be available to purchase in the UK and a max of around a month waiting time.
I would like the laptop to have a good screen, preferably 16gb of ram, good battery life and build quality as I want it to last me a few years.
The laptops I have been looking at already are
Lenovo T14s/T14 - R7 4750u, 16-32gb 512-1tb SSD 400nit 72% NTSC (Between £1100-1200)
Huawei Matebook 14 2020- R7 4800H 16gb 512gb ssd 300 nit 2k display 3:2 Ratio (£854)
HP envy x360 - R7 4700u 16gb 512 ssd 300nit 72% NTSC
(£949)
If you have any other recommendations or personal opinions about the laptops I listed it would be appreciated :D
Thanks 👍
https://linustechtips.com/topic/1260385-laptop-buying-help/
(£949)
Thanks 👍
So no gaming or difficult tasks to speak of.  I’m not sure you even need 4 cores or a discrete gpu. Or a lot of memory.  University often means lugging the thing from class to class so good battery life, light weight, ruggedness, and I/o are the major factors.  What about a used MacBook Air?  Surface pro as well perhaps.
Edited by Bombastinator
https://linustechtips.com/topic/1260385-laptop-buying-help/#findComment-14139649
1 hour ago, Bionicx said:
T14s/T14
I would pick this
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1260385-laptop-buying-help/#findComment-14139737
  • 1 month later...
(£949)
Thanks 👍
Hey,
Before Buying laptop you need to consider different criteria, including screen size, battery life, Processor, and Ram. I bought acer laptop after reviewing this source and it helped me alot. Now i am fully satisfied with my choice and smoothly working on my projects.
https://linustechtips.com/topic/1260385-laptop-buying-help/#findComment-14307475
