Monitor packaging question
Solved by SolarNova,
Considering most people dont keep the box or foam packaging i'd say thats probably the best u can expect from your average seller.
The dead pixels and scratches would not have been caused by the way it was packaged.
As for the stand, depends on how flimsy it is, If it feels particularly flimsy i would not have it attached, however with a suitable amount of padding out, any stress put on the stand by the display itself, which is light anyway, would be minimal.
