The only airflow orientated case I can think of with solid panels is the Fractal Design S2 Meshify:
Are there any other good ones?
(Can be ATX or MATX)
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
https://linustechtips.com/topic/1259258-airflow-cases-with-solid-side-panels/
Lain Li Lancool 2 Mesh? https://www.amazon.com/Li-LAN2MPX-LANCOOL-Performance-Black/dp/B08CSQWF6V?tag=gamersnexus01-20
Check it out.
18 minutes ago, Harshvardhan said:
It doesnt have a solid side panel, it's got glass?
50 minutes ago, GhostRoadieBL said:
The BeQuiet Pure Base series are also great
Pure base 500 could work but front looks restrictive, not sure I want to cut holes in it unless I have to...
Silent base 601/801 with solid panel looks good though, could probably brute force enough airflow
Coolermaster NR600P
MasterBox NR600P | Cooler Master
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
On 10/19/2020 at 8:13 PM, lee32uk said:
Phanteks P600S
Phanteks Enthoo Pro 2
I like the P600S for sure
Pro 2 is a bit too massive
On 10/19/2020 at 7:24 PM, TVwazhere said:
Coolermaster NR600P
I think this might be the winner! Only drawback is that it's the most expensive (not by too much though)
I still like the Silent Base 601/801 especially as i've realised that I can remove the front centre panel easily...
Thanks for the suggestions!
