Poor performance for decent build
Go to solution Solved by SkilledRebuilds,
The CPU can't do anything more, literally.
Your at the perils of that, and without reducing settings (less drawcalls, less usages but might only be a little gained) you kinda need a better/faster CPU for higher frames.
(you could try reducing any background apps/load) but it might only count for a few percent or less gains again.
I have an i7 4790 with a 1080 ti and my average fps is around 45 on 1080p high settings, any ideas for what the problem could be? I see my GPU reaching high 90% usage but CPU sticks around 50-60%
PC Specs: Motherboard: MSI Tomahawk X570  CPU: Ryzen 5900X  CPU Cooler: NZXT 240 mm Kraken Series AIO     GPU: Asus Strix ROG 1080 TI OC Edition    PSU: Corsair RM850 850W   Storage: 2 X 4TB, 2 X 1TB HDD And 1 X 1tb m.2 samsung 980 pro Case:  NZXT H440 2015 Edition
https://linustechtips.com/topic/1258434-poor-performance-for-decent-build/
Specifics...
Game in question?
To be fair its a weird pairing (NONK version of 4790+1080Ti/2080S)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
What game? What are you temps? What are your CPU clock speeds?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
We need performance monitor/logs
Download GPU-Z and or use https://www.screentogif.com/  Task Manager  (Ctrl+Shift+Esc) - (Interupts Sytem) Ctrl+Alt+Delete  Windows+X (on desktop)
Right-Click the Taskbar or search taskmgr Windows+R  any proccess running
Eufi Bios Settings & Specs
OS Build/OS
That is a weird pairing and I'd say, there probably is some bottlenecking. However, we need to know specs, like temps, clock speeds, utilization, etc...
It happens in GTA 5, my cpu temps do not go over 50c as its liquid cooled. Its the non-k version so it boosts upto 4GHz and has a base clock of 3.6GHz. 16 gb 1600MHz ram
edit: 1080ti enters low 60s while under high loads
2nd edit: I am also checking if a new CPU will actually be beneficial for me or a huge waste of money because if my CPU isn't bottlenecking that much then I don't know what to do.
Is the memory in the right slots for the mobo?
Nevermind, it only has 2 slots so assuming you have 2 sticks, you cant mess that up.
If you have 1 stick, then which slot is it in?
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
GTA V is NOTORIOUS for needing Singlethread performance across a Couple threads. (not all of them get loaded)
Your clockspeed limited with a 4790 (Ram is also limited to 1600Mhz on NONK, K-skew motherboards allow 1866/2133/2400Mhz Ram to be used)
My 4790K at 4.8Ghz with reduces settings (For FPS values to skyrocket) and I top out at 110-130fps (still not using the GPU to fullest)
Thats the limit of my 4.8Ghz
^Singleplayer.
Multiplayer your also at the perils of the SERVER, many threads are made on LTT for GTAV isn't running well and its the MP environment doing that.
3 minutes ago, NetherSand said:
Yeah if it runs in single channel it may be the problem
only 2 dims and have 2 8gb sticks so cant go wrong.
^Singleplayer.
So the new ryzen 5800x would be a solid choice and that leaves headroom for any new GPU that i may put in down the line like a 3080 for example.
As I always say before upgrading hardware. Update your BIOS and your drivers.
However sometimes with older cards there is a magic driver version that they run best on and new driver versions and can hurt them. I had a GTX 780Ti that was 5 years old I had to keep on a pre-VR Driver or it would cap at 40fps on games like CS:GO.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
That will be HUGE for you. (Moreso other games using 6Threads+) but yeah, even 2Core or 4Core based games will see a nice jump there..
If you had a 4790K i'd suggest (if not a stock cooler) overclocking it to say 4.5-4.6Ghz
But not the case,.. a Ryzen 3600/3700/5600/5700 all have better IPC than Haswell, Higher clocks, memory bandwidth and an allround greater experience.
If there are any background tasks in your system tray, try reducing what you need running when playing games....
I have checked if there are any updates for the BIOS but the latest one was released in 2016 which i did upgrade to. I have also attempted finding the best driver for the GPU but apparently the difference is minor if any
Well zen 3 is around the corner so i'd wait for that but I have heard that the i5 10600k is really solid for gaming and outperforms all ryzen CPUs. Perhaps I should wait for zen 3's benchmarks?
Await Zen3, compare performance vs price and yeah,.. choose based on needs.
Intel 10600K/10700K or Ryzen 5600/5700 will be great vs what you currently using.
Again, wouldn't be a big deal for the 4790 if you only had a GTX1650 but yeah, you have a beast GPU :)
I would hazard maybe looking up some GTAV optimization videos to see if for the meantime you could up the 45-50FPS to something better..
Or load the GPU further (Visuals increased) with the same framerates..
Thanks, ill give it a go! :)
Heres an update, I have attached some pics of my utilisation of RDR2 on 1080p high settings.
IMG_5076.HEIC IMG_5078_2.HEIC IMG_5079.HEIC
IMG_5076.HEIC 2.92 MB · 1 download IMG_5078_2.HEIC 2.61 MB · 0 downloads IMG_5079.HEIC 1.4 MB · 0 downloads
Can't open them.. what file format is that?
I don't have Photoshop or anything of that nature..
jpg will do..
jpg will do..
Sorry, they were airdropped to my laptop and were put into HEIC. This should work now
Guess the CPU is the next choice :D
