HI in most of my games about every 30 seconds I will get a fps drop from whatever fps I'm at to about 50-60.
My specs are
i7 9700
gtx 1660 ti
16 gb ram
my pc can handle all the games properly but recently the issue stated above started. If you need more info let me know
https://linustechtips.com/topic/1256682-fps-drops-every-30-seconds/
My specs are
i7 9700
gtx 1660 ti
16 gb ram
probably some windows background function, try stopping "most" background processes and restart your pc, then try again! :)
YES, I RUN RAID 1 OVER RAID 0
REMEBER TO QUOTE 😜
1 minute ago, MrCrextor said:
I have my background apps turned off
Noo... Try to disable all startup programs from task manager, or the way i do this, I backup my data, every month, install windows again, and then put the data back, it doesnt take that long, and each month, the PC runs very smooooooooottttttttttthhhhhhhh, you dont have to do this though each month though
REMEBER TO QUOTE 😜
ohh ive done that too(start up programs). do you use the "reset this pc" option?
What games, what settings, and what resolution?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Reminds me of this Thread yesterday..
Please have a suss at the Windows GAME Recording DVR functions and if they are enabled, disable them and retest games.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
1 hour ago, MrCrextor said:
Almost any the most noticeable one is fortnite running full low setting locked to 120 fps in 1080p. When it drops it goes from my solid 120 to around 50
Thanks, I wanted to make sure it wasn't 4K or something. Do you have any RGB components? If so, try closing the utility. Also, if you have a mouse with an adjustable polling rate (basically any gaming mouse), lower the polling rate to 250hz. Often times they are set to 1000hz by default, which causes a lot of stutters.
I'll try to change my polling rate but for the rgb I have it controlled on board my mouse
10 hours ago, MrCrextor said:
Dam
that isn't really a solution anyways, success not guaranteed either...
I have reinstalled windows exactly 0 times since I installed it first about 2 years ago on my PC. Slowdowns not detected. On the contrary,it keeps getting faster since I disabled windows update services *completely*  😉
-Scott Manley, 2021
that's true all those RGB and "gaming" utilities can really f up a PC...
-Scott Manley, 2021
