You build is good, just upgrade the motherboard to something like a B550 or X570 tomahawk. For you PSU, click on it in your part list to go to the individual parts, then scroll down. On the left, you can find that it has: 12 sata and 4 molex. Also I think you should upgrade from RM series; they aren't very well built. Something like this would be better: https://pcpartpicker.com/product/P7pmP6/
EDIT: changed to 850w ver
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14101497
Thanks for your help but where do I plug in the molex???
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14101566
So... I'm seeing a trend here.  You don't like Corsair PSUs for some reason.
You tell him the RM isn't very well built... then direct him to buy a Thermaltake that is essentially the same platform from the same OEM.
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14101594
44 minutes ago, Technotgenius6 said:
Hi I've got a question about the corsair rm 850 watt. Does this power supply have a molex connector and how many sata cables and connectors does it have?? Here is my dream build is it good? https://pcpartpicker.com/list/vNrTvW
The RM850 comes with three SATA cables with four connectors each (total 12).
It also comes with 1 Molex cable with four connectors.
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14101603
2 hours ago, Technotgenius6 said:
Can you plug in a molex cable into the corsair rm 850 watt  and where do i plug it in?????
Only use cables that came with that power supply or one that is compatible with that PSU.
https://www.corsair.com/us/en/psu-cable-compatibility
PSU CABLE COMPATIBILITY
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14104082
Threads merged. You do not need to make 4 separate threads just to ask how many cables the RM850 PSU has.
You can find information about the number of cables/connectors the PSU comes with on the manufacturers website product page.
https://www.corsair.com/us/en/Categories/Products/Power-Supply-Units/Power-Supply-Units-Advanced/RM-Series™-80-PLUS-Gold-Power-Supplies/p/CP-9020196-NA#tab-tech-specs
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14126352
16 minutes ago, Technotgenius6 said:
I couldn't find it on the website for the psu doe?
it does have, 2x8pin.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14127539
Have you checked the link @Spotty sent?
It's got three PCIe cables, each of them leading to two connectors for a total of six connectors.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1255882-help-with-power-supply/#findComment-14127569
