I have an NZXT Kraken M22 AIO and a Ryzen 5 3600x. My CPU shows that it is 95C on idle in Windows, but in the bios it shows that its around 65C. Regardless something is probably broken but I'm not sure what. In NZXT Cam software, it shows my clock speed is constantly running at 3900MHz, but in Ryzen Master it shows the speed hovering around 980-1000 MHz idle. I have a few ideas to what the problem is, but I would like a second opinion. In the BIOS as well, I have a Gigabyte X570 Gaming X board, and in the bios under Smart Fan 5 I put the speeds to "Full Power" (or something similar). My best guess is that my pump is failing/failed but other than that I'm not sure what the issue is.
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/
2 minutes ago, Electronics Wizardy said:
Is the pump worling correctly? Does the pump make any sounds.
Probably time to rplace the aio, is there a warranty?
Last night when I tried to troubleshoot, I could feel the pump working but other than that its silent. Also I'm sure I have a warranty, I'll start to contact them. Also I'm not sure if this will just be for no reason but later today after school I will be repasting and reseating the cooler to see if that can fix the issue.
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/#findComment-14077737
How is the AIO mounted?  Possible air bubbles trapped in the pump?
Otherwise I'd reseat and then RMA it if it doesn't fix it.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/#findComment-14077755
What program is saying 95c?
you may have forgotten to paste the cpu or the pump is going.
if you have the cooler that came with you cpu, put it on for now
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/#findComment-14077882
Pretty much every program I have (GPUZ, NZXT Cam, Ryzen Master, HWInfo) say it runs 95C+ on idle. I still need to dig out my stock cooler though lol. Also just re-seated and re-pasted my CPU to no avail, I still have the same issue.
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/#findComment-14077976
Sounds like a dead aio. Grab that stock cooler and contact nzxt
https://linustechtips.com/topic/1253213-cpu-temps-95c-idle/#findComment-14078273
