That really isn't a bottlenecked system at all. What settings and resolution are you trying to play at, and also I am pretty sure the assassin's creed ports have never been stellar at performance.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14074492
7 minutes ago, Sagar16 said:
GPU  usage is 98 percentage and CPU is just  48 to 50 percentage is this not bottle necking ? /system is over heating
That's not a bottleneck at all since your gpu is pegged to damn near 100%
Main Rig
Plex Server WIP
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14074538
GPU bottlenecks are a thing btw. If the CPU is only at 50, and the GPU 100, either the game uses less cores, or the GPU is bottleneck the CPU.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14074559
26 minutes ago, Sagar16 said:
Hi
I bought a Asus rog strix G531GT and it is getting bottlenecked while playing Odyssey can any one suggest some thing for improving this .
Ram : 16 Gb ddr5
Processor : intel i7 9750H 2.6 ghz with turbo boost upto 4.5 ghz
GPU :NVIDIA Geforce GTX 1650
Run Prime95 in the background or sell the laptop and get one with better gpu.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14074573
-> Moved to PC Gaming
You got laptop. If you bought it as default config, you need to tweak game settings. There's nothing you can do hardware-wise.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14076653
Everything is as it should be.
GPU = High Usage
CPU = Low Usage
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14076677
No and no.
50% CPU, 100% GPU. Perfect.
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14076683
4 hours ago, Praesi said:
No and no.
no, but ok.
Bios database
prior build:
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14077091
2 hours ago, HelpfulTechWizard said:
no, but ok.
Dude please. What you said was Nonsense.
Dont take it personal and learn something instead of defending false Information.
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14077576
in a perfect world, a cpu and gpu would be pushed evenly.
Bios database
prior build:
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14077762
Again. Complete false.
OP, you are fine.
https://linustechtips.com/topic/1252879-system-bottle-necking/#findComment-14077865
