Hello guys!
I'm planning to upgrade my old cpu (i5 6400) for a new i5 10600K, but i have a few questions.
My current cpu is installed with a intel stock cooler, and i've heard those already include some thermal paste on the cooler. I'm planning to just reuse this cooler because my new cpu doesnt come with one.
But because i already used the cooler for like 3 years, is it necessary to buy some new thermal paste to apply to my cpu or cooler?
I would really appreciate some answers!
https://linustechtips.com/topic/1251697-cpu-thermal-paste-question/
2 minutes ago, Rubrix said:
Shouldn't i just apply some extra thermal paste instead of buying a whole new cooler?
And yes, that cooler is the one i'm using rn
It's up to you, but with that cooler your CPU might very easily overheat, be it new thermal paste or not.
Cooler Master Hyper 212 should be enough, though the price of a good cooler is varying depending of where you are located.
Pax vobiscum
well first of all, i5 6400k doesnt exist, but that's not the point of this thread
you CAN use that cooler, but it's not recommended
you're going to get very high temps, if not hitting the throttling temps.
you can use it first, see how it goes, if it's insufficient then get a better cooler
-sigh- feeling like I'm being too negative lately
37 minutes ago, Tan3l6 said:
If the original cooler looks like this, then do consider buying a proper cooler.
I would never use a Intel stock cooler on a newer processor as the heat output of the 10600k will be higher than the current processor. Also, grab a tube of high quality thermal paste, such as the noctua nt-h1 or equivalent. The majority of CPU coolers I see come with a small tube to get you going with the cooler (I know mine did).
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
