Hello I'm new to computers or at least the internals. I was looking to upgrading my GPU but I'm concerned it will cause a bottleneck somewhere else. I bought a rig for $100 and it came with a Core I7 quad core 920 @ 2.67GHz, 12GB of DDR3 1067MHz ram in 3 sticks, and a GeForce GTX 650. I'm thinking of upgrading to a GTX 1050 but not sure if its the right move to get more performance out of my machine. Any and all help would be appreciated.
https://linustechtips.com/topic/1250923-need-help-with-potential-upgrade/
You'll get some performance out of it, but I think if possible... It'd be best to upgrade the cpu as well with the 1050 depending on your budget.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
a gtx 1050 would be a decent match with that cpu, but would need to know where you are having performance issues to say for sure if gpu is the best thing to address first. if you don't have an ssd, that would be the first thing you would want to upgrade imo.
For further information I have a Intel DX58SO motherboard and a 750w corsair power supply. no SSD just a 500GB Disc Drive. The rig also has in one of the PCI slots a USB 3.0 expansion card. Oh and a disc reader/burner.
Thank you Br3tt and bmx for your input so far
Quote people so they see your reply even if they click off the page. Little arrow beneath my post.
I'd replace your CPU with a $50 6c12t Xeon like an X5650 or X5675, upgrade your GPU to a used 570/580 (probably $80-100), and throw in an SSD.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
they're more like $10 nowadays, might as well just get it with how cheap they are.
Interesting. Last time I checked most were hoving around 50 cad shipped.
SPECS:
Thank you I ended up ordering the CPU for 30 and spent 120 on the GPU. I plan on getting a SSD later as it's not in my immediate budget.
He would also have to upgrade the motherboard and likely ram as well if he wants to upgrade the cpu
What cpu and gpu did you end up getting?
Main Rig
Plex Server WIP
I got a XFX Radeon RX 570 and... Cancelled the CPU order. If you check my profile you'll see I have a proprietary Intel motherboard that they don't support. I went to install the graphics card and it doesn't quite work, well I need to update the bios as the motherboard is 10ish years old. I called Intel today and they don't have the files for it at all. Now I'm going to build a new system using my same case and power supply withe the graphics card I bought. I'm planning on building something AMD 3000 series CPU
