Hello I am new to this forum. I was hoping to get some quick advice on CPU cooling as I am having trouble managing my temps while gaming.
A quick overview of my setup-
CPU- i7 7700k
CPU cooler- Cooler Master hyper 212 LED
GPU- Zotac AMP GTX 1060 6gb
MOBO- ASUS Z170-P (not pro)
Case- Antec GX200
Memory- 2X 8gb corsair vengeance Black @ 3000 mhz
Storage- 2tb Seagate Barracuda HDD
Boot Drive- 250 GB Kingston SSD
PSU- 600 W Antec VP600W
Okay, so now that I have that out of the way. My main problem is the case airflow and CPU cooling itself. My 7700k is hitting temps of 95 degrees Celsius during gaming sessions and I am worried. I know i need to get better cooling but my case doesn't allow that many options and I am not in a position where I can easily change multiple parts on the go. I was hoping for any advice on which CPU cooler to get for my CPU. I know I need to get better fans for my case as well, which is why I will be replacing both the 2 intakes in the front and the single exhaust in the rear. Hopefully replacing the intakes and exhaust fans will give me better airflow but I still need better cooling for my CPU. Thanks in advance for any advice. Please keep in mind that my PC case only allows for 120mm fans.
https://linustechtips.com/topic/1250826-need-immediate-cooling-advice/
The 2 fans will help immensely.  You mention cabinet.  If the case is tucked away in a cabinet, pull it out and stop suffocating it.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Just now, NinJake said:
Do you have your i7 overclocked? If so, reset to factory settings. What is the ambient temperature of your room normally? Where is the PC located?
Wow, thanks for the quick response. No, I do not have it overclocked. IT runs at stock speeds between 4.2 -4.5 GHZ. I am not too sure about the ambient temperature of my room but overall the climate where I live is more humid than hot (28 C- 35C).
My PC is located near my room's window but nevertheless I would like the PC to be able to overclock as well without worrying about temps and I was wondering which cooler would help me do that.
Sorry, I meant case. Usually where I live, most people use the terms case and cabinet interchangeably.
I'd look around on pcpartpicker (website) in their CPU Cooling section. If you want to go with a liquid AIO cooler you could try that, otherwise I'd get the largest tower cooler that fits with all your components. I'm not sure off the top of my head but my work computer uses the Cryorig H7 and my personal is the Noctua NH-D14 (beeeefy).
1 minute ago, emosun said:
yeah and 35c is 95f
if your room was 90f that would be pretty absurd how do you sleep in that?
IDK that's pretty normal where I live lol
Temps do come down to 25 C at night but during the day, it's around 30-35 C.
ok well blasting hot air through the machine isn't exactly going to cool it off very well. Without the room being at the temperature of a normal building which is 70-72 then i wouldnt ever expect it to run cool.
Those are some thick boys there. My case isn't that small as it supports a standard ATX MOBO but I would have to check the size before buying I guess. For now I just need a cooler that can handle my CPU temps.
LOL that's winter in my area. I guess I gotta get an air conditioner then.
I was considering the NZXT Krakken m22 AIO cooler and was wondering whether I could mount the radiator as an exhaust at the rear of my case.
1 minute ago, Caroline said:
not that much tbh and not everyone has A/C in all rooms, pretty sure that's an US thing, in the third world we just cope with it
95C though... that CPU must be throttling, even with the high ambient temp it shouldn't be that hot, the 7700k has temp problems so it needs a delid and TIM replacement, or a big air cooler with lots of airflow, or both.
The GX200 has decent airflow, with the 3 fans working should be enough
So getting an new CPU cooler won't be as effective as getting  new fans for my exhaust and intakes? I feel like I can make some improvements if I replace the CPU cooler as well. My current Air cooler is running at max fan speeds and has idle CPU temps of 55-68 C while gaming it goes almost upto 95C.
Or you could actually check that your cooler is working properly first...
Remove it, clean of any thermal paste from the CPU and the cold plate, apply some new paste, re-attach your cooler and make sure it's making good contact at a decent pressure.
Even an air cooler should keep your CPU below 95C under most work loads if it's fitted properly and isn't just the crappy stock one that came with the CPU and you're running stock.
Edit for last reply: Idle temps of 55-68C definitely leads me to think your cooler either isn't making proper contact or your thermal paste has dried up and hardened.
I did that a few weeks ago. I cleaned the old paste properly and reapplied new thermal paste. Still getting the same temps. Idle is around 55-68 C and under load it almost reaches 95 C
Idle temps of 20+ degrees over ambient are terrible, the Hyper 212 is a budget cooler but it's one of the better budget ones.
Have you checked to make sure your fans are properly installed in a push-pull configuration?
You wouldn't be the first person to think they were only to find out they were all exhausting or vice versa... Definitely NOT speaking from experience there... nope definitely not...
AIO's are also of course always good options if you have the budget and the space in your case.
Edited by Mn3m3nth
additional comment
4 minutes ago, emosun said:
gee almost as if running hot air into the machine was a bad idea or something....
in b4 buying a new cooler doesnt fix it
I don't know where you get the idea that 35C is particularly hot, it's not. If it was you wouldn't be able to use a PC in any "warmer" country without exotic cooling.
Coolers work with a delta above ambient, 20deg+ is bad, it has nothing to do with the starting ambient temperature, that's why it's a delta.
However yes a new cooler will almost definitely fix it as it sounds like the current one is faulty or just isn't up to the job.
Just now, Caroline said:
No no that's not what I've just said, both will be effective, just FYI getting overly expensive fans won't be any different than getting cheap case fans in terms of cooling, a $10 and a $100 fan will both do the same which is push air through the case. Looks and noise may differ from one to another but that's it.
You will improve temps by replacing your CPU cooler, the 212 isn't really enough for a 7700K, you could get let's say a Dark Rock TF and uh some MX-4 paste and your temps will definitely improve, you'll still have to bear the 95C spikes (not constant temps, just spikes) though as it's a CPU problem
Yeah the CPU itself isn't that great but I didn't have a choice since that's the highest gen my MOBO can accomodate. I'll look into getting a better cooler though. I only bought the 212 because I was in college when I started this build.
quick google search shows
https://www.google.com/amp/s/www.techspot.com/amp/news/69204-intel-responds-i7-7700k-high-temperate-issue-tells.html
I think your cpu is just pretty terrible and you didn't do proper research before buying... especially when living in an hot environment (yes I know it's to late now just something to think of in the future)
that said  maybe a noctua CPU air cooler and a couple of (as many as you can realistically fit) noctua case fans would get your CPU 5-10C cooler. yes I know that doesn't sound much I think it's realistic though. Also high end thermal paste could be an option. but be careful some of those are electrical conductive, so do at your own risk and only if you're actually sure you can handle it.
tldr I don't think your temps are abnormal, just a bit unfortunate.
-Scott Manley, 2021
