Maybe a standby LED.
If you don't have any problems, this can be ignored.
https://linustechtips.com/topic/1250261-can-someone-help-me/#findComment-14050014
the one by the io shield is usually the lan light.
If there is no problems, then what is the issue?
If its aesthetics, little electrical tape or black sharpie can fix it all right up.
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/1250261-can-someone-help-me/#findComment-14050042
26 minutes ago, Bad5ector said:
@miagisanThat sounds dangerous... but then again... that is your middle name ;)
To the OP, I'm just kidding it isn't dangerous. Just a fan of Darkwing Duck.
One of my favorite shows during my childhood....soo many moons ago.
— Grumpy old man
https://linustechtips.com/topic/1250261-can-someone-help-me/#findComment-14050123
