Dust Filters For Fans
DriedSponge
Should I buy dust filters specfically made for PC intake fans, or are there better "diy" solutions?
Remember to quote or @mention others, so they are notified of your reply
AMD Ryzen 9 5950X | Arctic Liquid Freezer II 360 | MSI B450 TOMAHAWK MAX | G.Skill Trident Z RGB 32 GB DDR4-3600 | Gigabyte GeForce RTX 2080 SUPER 8 GB
Samsung 980 EVO Plus 2TB | SK hynix Gold S31 500GB SSD | Seagate Barracuda Compute 2 TB 7200RPM HDD | 1TB Samsung 860 EVO SSD | 3x Phanteks T30-120
Corsair RM1000e 1000 W 80+ Gold Certified Modular PSU | Corsair 5000D Airflow Windows 11 Home
Does your case not already have filtered intakes?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
It came with one magnetic dust filter for the top fan, which I moved to one of the front fans because I use top for outake. It also came with a dust filter for the power supply fan. Here is the link to the case if you need more info:
https://www.newegg.com/black-phanteks-eclipse-p300a-mesh-edition-atx-mid-tower/p/N82E16811854097?Item=N82E16811854097
Isn't the front mesh panel already acting as air filter?
No it does not. I put the magnetic dust filter right behind the mesh and found that the mesh was catching little to no dust.
