Streaming audio from ipad to pc
gggb
I play pubg mobile (please don't judge) on my ipad and sometimes I just want to watch a movie or listening to music. Is there a way I can stream my audio on my ipad onto my pc via cable? Free is always better.
p/s: so far I use the air stream thingy on pc, it works fine but there is a huge delay so I would rather try connecting it via cable to get rid of the delay.
You can plug in your iPad to the Line In jack on the back of your motherboard or sound card if they support it. You'll just need a standard 3.5mm male to male audio cable. Then in your Audio settings, enable Listen to this device for the Line In recording device. This is probably as close to free as you're gonna get. Any alternative that I can think of would require some additional hardware mainly if your motherboard or sound card does not have Line In.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
18 minutes ago, BlueChinchillaEatingDorito said:
You can plug in your iPad to the Line In jack on the back of your motherboard or sound card if they support it. You'll just need a standard 3.5mm male to male audio cable. Then in your Audio settings, enable Listen to this device for the Line In recording device. This is probably as close to free as you're gonna get. Any alternative that I can think of would require some additional hardware mainly if your motherboard or sound card does not have a Line In.
worked like a charm, thank you so much man
You're welcome! Glad to help
