With these current parts selected I am wondering which itx case would be the best. I am trying to fit an RTX 3080 FE card in it and am struggling to find something that will fit all these components.
https://linustechtips.com/topic/1246735-need-help-choosing-an-itx-case/
Do you have certain volume requirements? A lot of this could fit into something like an NZXT H210i but it's a large case for the ITX market.
Not necessarily as long as it's itx and will fit these components it should be fine.
28 minutes ago, TVwazhere said:
This looks absolutely perfect thank you so much.
