Hey all
I'm currently going through the issue of trying to remove trapped air in my loop. I tried tipping my case and stuff back and forth to try and release the trapped air.
Is there anything else I can do or should I keep tipping back and forth to try my best to get it out.
Thanks
Laboon
https://linustechtips.com/topic/124271-air-trapped-in-loop/
What kind of bubble are you talking about? Big bubbles will usually go away pretty easily by just cycling the pump, jiggling the tubing and tilting the case. The smaller bubbles stick around longer, but they don't really affect performance, so you don't have to worry about them. They will slowly get flushed out in a few days.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1653157
Put the absolute tiniest fraction of a drop of dish soap into your loop.
I mean not even a drip, a very small drizzle. It should help dislodge bubbles, in addition to flicking the tubing and shaking the case violently.
Error: 410
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1653196
Not sure I would shake any case violently.
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1653207
These bubbles naturally go away after a few days. Just let them go away on their own unless you can't wait to take pictures or something.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1653223
It has been about 2 months since I put my loop together. On my variable speed pump, on setting 4 and 5 I hear (what I think is) the little air bubbles rattling around in the pump but from 3 and lower, it goes silent. If I keep it on setting 3 then my system starts getting quite warm (r9 290 and 8350) and I'd rather keep it cooler with a faster setting.
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658024
Like I said, add a tiny dab of dish soap or concentrated water wetter or something.
Error: 410
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658045
Ive never actually heard of this. How does it help?
Science I never bothered to look in to and cannot elaborate on, it's literally lubricant for an aquatic system. Of course you're welcome to look it up yourself.
I cannot stress enough to use a tiny amount of dish soap or else it will have the opposite effect and add more suds.
Error: 410
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658060
Throw your case out the window.
Well, you won't have to worry about air bubbles if you do this... :)
CPU: i7-3820 | Cooler: Be Quiet Dark Rock Pro 2 | Mobo: Asus Sabretooth X79Memory: 2x8GB Corsair Vengeance LP | Storage: Crucial M500 240GB & 480GB SSD + Western Digital BLACK SERIES 1 TB |
GPU: EVGA GeForce GTX 780ti Superclocked | PSU: 1000W Be Quiet Dark Power Pro 10 | Monitors: 3 x AOC i2367Fh 23.0"
All hail the mighty Flying Spaghetti Monster. May he touch you with his noodely appendages
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658373
what about washing machine soap. its engineered to be far less sudsy
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658401
not too sure about that, frequently those detergents are quite biologically active.
it might work the same but I've never heard of someone trying that.
Error: 410
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658406
screw it, I am putting this in my loop instead of water watered down a fair bit to increase viscosity.
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658423
that sounds like a bad time
why not antifreeze or something glycol based
Because I love the smell of tide  :D (much sarcasm)
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1658455
Hey all
Thanks
Laboon
What you should do is turn off the power to the pump and then tip it and then while it is tipped after making sure no water can spill out from your loop, turn the pump on and see if the air moves and if it does do it a few times to remove more air.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/124271-air-trapped-in-loop/#findComment-1659711
