CPU Fan has no control
Go to solution Solved by LogicalDrm,
36 minutes ago, MrTuffguy said:
Speedfan doesn't detect the fan at all
Then the board doesn't use any common fan control chip.
My PC's cpu fan doesn't seem to have any control. It's at full blast even when I'm not using it, the fan itself is a local stock intel model fan. I have looked and the fan is connected to a 4pin header and has 4 pins. There is no option in the bios or any other software to control the fan. AND IT'S REALLY LOUD.
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/
It's a local company called frontech
Full model name, please. But just from that I can assume its close to OEMs you have in Dell/HP machines. Meaning that it either has locked controls or none. You can still try with Speedfan or FanControl, but those OEM boards are always bit hard to configure.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13989017
It is a Frontech H61 FT-0470 Mainboard
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13992520
Frontech DDR3 / 1155 Socket Intel H61 Chipset Motherboard 0470 https://www.amazon.in/dp/B083WRFNYP/ref=cm_sw_r_cp_apa_i_Kg5uFbDGZ0R09
https://nuevotechindustries.com/product/h61-motherboard/
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13992528
10 minutes ago, MrTuffguy said:
Have you tried to see what Speedfan or FanControl look like? Chipset is old enough that Speedfan could work.
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13992554
1 hour ago, MrTuffguy said:
oh ok, so what can I do? or i can't control the fans in anyway
You could get hardware controller. One with knobs or one with USB and software.
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13996888
1 minute ago, MrTuffguy said:
And connect the fan through the controller? Nah too much effort. Thanks for the help Logic
And probably not worth money-wise either. But that would be the only option if motherboard doesn't have controller chips.
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13997993
Hey Logic also my fan doesn't stop if i put my pc to sleep is that normal?
No, but you have OEM board. It could have some custom power savings functionality going on. You could contact the manufacturer about it.
https://linustechtips.com/topic/1242416-cpu-fan-has-no-control/#findComment-13999629
