Stuck deciding on a case
Solved by Moonzy,
3 minutes ago, KT1578 said:What else would you recommend that would nicely show off the case interior and works well with RGB?
https://www.fractal-design.com/products/cases/meshify/meshify-c-tempered-glass/white/
one of the best cases in the market
2 minutes ago, KT1578 said:is the Meshify C much better? I also heard it gets much noisier due to low sound insulation but I'm not too sure
a ton better
it's more open, but that also means your fan dont have to spin harder and faster to cool your things, so they can spin slower, making it actually more quiet in some cases. pun intended
