3080 8 pin power question
IC4
So I’ve seen some pictures online of some aib cards that in place of a 12 pin I see 3 8 pin connectors? Is this seriously going to be the norm? Almost feel like I wasted my money on cablemod cables because they only supply 2 8 pin connectors so I’d have to use one of my seasonic supplied ones (that came with psu). Just wondering if there will be any 2 8 pin and a 6 pin or just two 8 pin 3080s. If anyone knows that’d be great.
If you can "waste" $1400+ on a 3080, you should be able to "waste" another $20-30 on an extra cable from cablemod. You can buy cables separately, not just as a whole kit.
Quit your whining.
Someone will eventually create a converter for this.
Or the OEM partner will supply such converters inside the package.
Quit your whining.
Alright if you can link me a 8 pin pcie white modmesh cable that ships to the USA then I’ll quit but I couldn’t find it.
Quit your whining.
Also a 3080 does not cost 1400 dollars so your on something. I think your mistaken for the 3090
When I was looking at the other manufacturer board images, there were some models with 2x 8-pin on them. I think the Asus TUF was one, but you'd have to check each candidate out. The 3rd power connector wont be needed outside of the high end cards that allow more extreme overclocking.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Go to https://store.cablemod.com/configurator/
Select Custom PSU Cables  or PSU Cables  (start with custom, then try psu cables if 1st fails). Hit Next.
Select your psu brand , then select model . Ignore the case question. Hit next/Continue
Select modmesh , white
Select the cable you want, click on the + button to add
Select your color then click on each cable to colorize it with that color (you can make multi color cables)
hit next, add combs if you want or other crap.
yeah, made jpg screenshots ... fuck it can't be bothered.
I guess cablemod will already be hard at work to get the 12-pin cables on sale.
Back to your question: Afaik several partner models of the cards use normal 6+2 type connectors.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
I appreciate the informative post, I really was not aware of this. And I know it sounds weird I wasn’t trying to “whine” it’s just obnoxious I gotta pay 20 dollar shipping for one cable. In the grand scheme when buying a 800+ video card that shouldn’t be a big deal but it’s the principle of the matter.
